Verizon sends a new D-Linl DSl 2750B Modem/Router and it keeps shutting down and has to be Restarted ...for a while its OK but shuts down ?
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
SOURCE: Actiontec GT 704 WG Verizon to Frontier
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
SOURCE: Cannot get PPTP VPN to connect via Westell 327W (Verizon DSL)
Is the VPN server that you are trying to connect behind a firewall?
SOURCE: d-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
SOURCE: Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
