Everything is jammed. Needle will not go up and down. None of the parts will move.
SOURCE: balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
SOURCE: machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
SOURCE: My machine jammed/bent needle & gave error message
p { margin-bottom: 0.21cm; }
Hi, According to your problem, if you have
change/replace the niddle properly then you can try to change the
niddle position to solve your problem. Check the niddle threading and
reset it. Check also the thread sensor. Reset the machine and unplug
it after resetting for 2 min. Then plug it and turn it on again. If
it doesn't solve your problem then you may need to reload the
software.
SOURCE: I just tried using my
No......CHANGE the needle,,,,it will damage your fabric!!
GET IT SERVICED....It needs retiming by the sound of things
