I just got it and am tring to get it to vacuum the air from the bag. The pump runs but nothing happens. Then I get and E01 message on the LED screen. The manual is no help.
HELP I have vacmaster pro 130 and the vacume pump runs and it will not pull a vacume.Theres no packing part left and or pressing down on it will not help.It seems that the pump is not hooked up becouse it run but not pull a vacume.And it shows E01 on led screen WHATS WRONG
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Testimonial: "This was solution #1. The second one is the press the top down during the vacuuming stage. Apparently when the seal is new it isn't flexible enough for the magnet to draw the top tight enough. Thanks for your help."
WHAT DO YOU USE ON THE SEAL TO HELP THEM VEG OIL OR SUM THING
I DID PRESS DOWN ON THE LID NOTHING
i NOW HAVE THE SETTING ON HI ON THE VAC
cAN YOU HELP ME
Can you call me please at 507 469 5245 thank you.Ask for Bruce
I've been fighting the same problem for some time and recently experimented with the bags not the machine. If you take the open end of the bag you are trying to vacuum seal and Wrinkle it really well, the VacMaster Pro 130 will work properly again without the EO1 error code popping up.
