Clock and setting ok. When set does not turn on. Where can I get a factory service manual?
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
thank you, thank you, thank you. you saved me $500.00. my oven was heating one day and stopped the next. i read your solution and it was the omron relay. it shed the solder on one of the pins. i applied solder to the pin so it made contact with the board and the oven works perfect again. thank you so much.
