Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
First would be to name the subwoofer so we can look at its "Line OUT's". The IN's would be more important as far as ITS function goes. I'm sure a manual exists for the unidentified subwoofer.
This receiver has direct subwoofer amplifer for a passive (unpowered) subwoofer as well as a Subwoofer Line Out for controlling an active (powered) subwoofer amp.
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
I found a manual online, and learned that there is a speaker set-up procedure on this Onkyo model ... so when it got to the subwoofer set-up, I simply went from "subwoofer off" to "subwoofer on"
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
