Only problem is the freezer freezes up until water leaks on to the floor
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
SOURCE: I have a whirlpool sided by side refrigerator
Remove the food and the shelves , and the crisper , blocking removal of the inside rear freezer panel . Remove the 4 screws holding the panel and remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an aluminum solid wire ( fence post tie , ground wire , etc ), 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
SOURCE: water leaking from freezer into refrigerator
This is most likely due to the defrost drain being restricted, here is a link to help explain how to correct the problem. Let me know if this helps. Thanks.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
