I was pushing buttons, and locked my control panel... How do I unlock it ? (I can't change the temperature, or turn on the pumps)
SOURCE: I have just refilled by
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
SOURCE: Marquis Hot Tub, Instrument Panels (Balboa
The topside controls aren't fused so the fuses wont be the cause.
It can only be either the PCB, the topside controls, or a bad connection at fault. Check that they are plugged in correctly, make sure that the PCB is configured correctly for your topside controls.
It's rare for both the main and auxilary topside controls to fail. You can try plugging in another main topside control without fully installing it... at least you can then return it (ask whether or not return are accepted, I don't personally accept any returns if parts are specially ordered) if it doesn't cure the problem.
Regards,
Ian.
SOURCE: I just bought a used
This does not sound normal, but in order to better diagnose this I need to know exactly what model of controls your spa has. This is easily found on a label on top of the control box in the spa cabinet. If the label is missing, then remove the control box cover and look at the inside of the cover for the schematic, should be a model number on it.
SOURCE: When I power on the
Hi, you have a faulty upper control panel which is as a result of a circuit board fault. You need to replace the control panel..
