Sharp AQUOS  LC-32GP1U 32 in. LCD HDTV Logo
A
Anonymous Posted on Jun 02, 2012
I have a sharp aquos lc-60e69u tv and hooked up my xbox 360 to it and the pic is not high quality and there seems to be lag goin on. how do i fix this?
5 Related Answers
A
Anonymous
  • Posted on Jan 25, 2008
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Anonymous
  • 19 Answers
  • Posted on Apr 03, 2009
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Anonymous
  • 31 Answers
  • Posted on Apr 29, 2009
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
trashcansd
  • 73 Answers
  • Posted on Sep 27, 2009
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Anonymous
  • Posted on Oct 19, 2009
SOURCE: Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Are my control buttons broken, or is it another problem?
The simple fix is stop playing with the side buttons and buy a new remote for $24 :>D If you really like playing with the side buttons, open the set up and spray the contacts behind the buttons with Switch Cleaner (NOT WD40).
New 845-039-40B0 Remote Control 84503940B0 fit for ...
https://www.amazon.ca > 845-039-40B0-LC-40LE431...
New 845-039-40B0 Remote Control 84503940B0 fit for Sharp LCD TV LC-60E69 LC-60E69U LC-40LE431U LC-40LE431UA LC-40LE433U LC-40LE433UA LC-40LE433 LC-40LE431 ...
Compatible devices: Television
Brand: AIDITIYMI Rating: 4.7 · ‎137 reviews · ‎$27.77
People also ask
Will any sharp remote work for any sharp TV?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> What do I do if I lost my Sharp TV remote?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Is the Sharp Aquos remote universal?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How do I pair my sharp remote?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Feedback
845-039-40B0 Replacement Remote Control Applicable ...
https://www.amazon.com > 845-039-40B0-Replacemen...
Buy 845-039-40B0 Replacement Remote Control Applicable for Sharp LCD TV LC-60E69U LC-40LE431U LC-40LE431UA LC-40LE433U LC-40LE433UA LC60E69U LC40LE431U ...
Rating: 4.5 · ‎38 reviews
845-039-40B0 Replaced Remote fit for Sharp TV ... - Walmart.ca
https://www.walmart.ca > 845-039-40B0-Replaced-Rem...
Buy 845-039-40B0 Replaced Remote fit for Sharp TV LC-60E69U LC-40LE431U LC-40LE431UA LC-60E69 LC60E69U LC40LE431U from Walmart Canada. Shop for more Remote ...
Brand: Vinabty factory
Number of Pieces: 10
Can i hook up my xbox 360 to my aquos tv with just the red, yellow, and white cable? Right now I am not getting a color pic
Yes you can but it won't be Hi def. It sounds like you're trying to connect the cables to the Hi def input (Red, blue, green, white and red for the audio) That's not the right place to connect to.
2answers
How do i hook up my xbox 360 to the Sharp Aquos
You have a few options actually. depending on which 360 you have you have at least 3 ways to connect; 4 if you have CDMI cable output on Elite 360. you only need to pick one though. easiest is the plug with one yellow and a red and white. the yellow is the video and the red and white are the left and right audio. You can use the red green blue plugs choice if your tv has that input. in that case the red green blue are the video and you use the other paired red white for audio. You can use the S video connection (the round one that looks like a mouse plug) for video. You can use the HDMI (flat, looks like giant USB slot) for really high quality video. So, basically just use whatever cable you happen to have. If you still have questions, please ask as we will definitely get you hooked up for sure:) farmerbear at FixYa
1helpful
Tv screen keep going black,
did you check the sleep mode on the tv?
1helpful
Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
2answers
Sharp LC=32D43U display capabilities
is the switch set to hdtv on the cables... and are the display settings in the dashboard set to hd
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
