Sumthing's really wron g with my sansa e200 when i turn the unit off the only display that i get is "Load main image failed Switch to recovery mode"
Check ot dis link it works
http://www.freewebs.com/recoversansa
Check ot ds link it works
I had this same problem with an e250R (Rhapsody). ****YOU GET THIS MESSAGE WHEN YOU UPLOAD THE *WRONG* MODEL FIRMWARE***** The player IS NOT "bricked", the fix couldn't be easier. I called SanDisk support (1-866-726-3475) and they explained it to me. To find the CORRECT firmware for your player, just go to sandisk.com, click on "music and video players", click on the series you have (I have a e250R, so I clicked the e200 Rhapsody series), then click on your exact model number. To the right you will see "Firmware Update", click it and then download the firmware zip file. You start the player in recovery mode like you did when you effed it up with the wrong firmware, then just copy this file to your mp3 player's drive letter and then unplug the player from your PC. Reboot your SanDisk player normally. Presto; your fixed. If you cant follow these directions, then call SanDisk yourself and someone will even hold your hand through it! You paid for support when you bought the darn thing, USE IT.
Omg. that Totally Worked!! i Hate My Sansa E250, it ALWAYS Has a Problem!! Whether it Be W/ My Songs. A lot of my Songs Say "Bad Song" and it Skips. And Some Are on my device and they don't even work, killing my space!
Version Info: Product Rev.: PP5022AF-05.51-S301-01.01-S301.0.1.47-D
Base Code: 05.51-S301-01.01-S301.0.1.47-D
ODM Ver.: S301-01.01-S301.0.1.47-D
OEM Ver.: S301.0.1.47-D
Build Type: -D
Build Date: 2006.10.07
Build Number: (Build 169.31)
load image failes switch to recovery mode
please help me with my sansa e250 reply me at [email protected] thank u in advance
I have a problem where it doesnt screen remains black after i turn it on
and if i try the recovery mode
windows just pops up saying new hardware found
but i cant install any hardwhere to recognize it
What i did was connect your mp3 player to the comp in recovery mode.
-Download the firmware for the corresponding player(mine is e260r) from the sandisk website.
-Unzip this firmware.Copy the contents of this folder into the 16MB Format you get when you plugin the player.
-Plug out the player.The player will reset.
-Success.....
This is the real 100% way that mine worked.
Place the two files in SKU_E and sansa.fmt into 16 MB format.
Then just unplug it
I had a problem with my e260 starting. The screen would turn white and keep restarting. I followed the "best solution " on this site and it worked for me. I tried following suggestions on other websites and they all seemed to reinstall the firmware in recovery mode but my problem didn't change. One peculiar thing was when i clicked on the icon in my system tray it referred to my Sansa as an e250. Thanks for the help
Thankyou soo much.. got it working.. cheers
There is now a "Sansa Connect Recovery Tool" located at mp3support.sandisk.com/tools/DeviceRecoverySetup.exe I believe you need to put the player into recover mode with the "Hold/Record/Menu" buttons. Then run this recovery program. My player is completely shot and I can't even get it into recover mode now.
I have also encountered the same problem. "Load main image failed Switch to Recovery Mode" What I did was: 1. Download and install the Firmware Updater Software from SanDisk "http://www.sandisk.com/Assets/File/Downloads/firmware/SansaUpdaterInstall.exe" 2. Bring up the Sansa into recovery mode by: -Switch the Hold Switch to Locked Position -Hold (and continue to hold) the Record button -Press the menu button (may a need an extra hand) while plugging in the USB Cable to the computer 3. After the Sansa is in the Recovery Mode saying: "... Enter 2.0 MSD" (Means that it is currently in MSD) 4. Right Click on the Sansa Firmware Updater icon in the System Tray (near the clock) and select "Update Now" 5. Once the dialogue box appears, DO NOT SELECT AMERICA, but chose Japan and Update. 6. Follow it's procedures till the end. -The screen will tell you to unplug then press finish. BUT WAIT! -I press the finish button first, then right click on the "Safely Remove Hardware" icon on the System Tray and properly stopped the USB device. -After stopping (and unplugging), the Sansa's screen continues with the rebooting process and finishes the update. -It will automatically restart, but the Hold Switch is still on Lock. I must then turn off the Hold Switch and press Menu to turn on the Sansa. -So far, it seems to work. In summary, I think the "America" download site doesn't have the latest firmware to fix this problem, but the Japan site does. Next, the improper unplugging of the device may prevent the update process to complete. I've seen from other forums that people who had prematurely (improperly) stopped the updating process. This one really works tanks guys :)
Solution 2 is exactly how to get it back again. "but after you do all that it will tell you to enter the usb 2.0 MSD mode and i have no idea what that is" The drive pops open, and you can see all the files on the sansa. Hopefully you'll have a copy of all the system files from before the format... just copy them back onto the sansa and you're done.
He's absolutely right, but if this recovery mode doesnt work, then reformat the mp3 player and start from there.
Well mines doing the same thing and so far i've only figured out how to get it in recovery mode but that really doesn't fix anything. for the recovery mode: put the player on hold hold the record button turn the player on and plug it in to the usb port but after you do all that it will tell you to enter the usb 2.0 MSD mode and i have no idea what that is
SOURCE: sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
how can i fixed my sansa mp3 because it says load image failed Switch to recovery mode.
please help with this problem.
load main image failed switch to recovery mode
i have a problem of main image failed in my sansa e250. i have used all the procedure but my player still shows this error. i have paste pp5022.mi4 file in 16-mb format folder, but it shows that "load main image fail" .
I also try it by pasting "sansa.fmt" file in 16 mb folder but still it shows the same error.please suggest me what to do as earlier as possible.
thanks
Im doing great till step 4. Sansa Firmware Updater icon in the System Tray (near the clock) and select "Update Now"
The icon does not show up after i connect it, and it is installed. and when i go click it manually in the folder it says only update service can run it.
i unplugged my mp from the usb cord and now it say load main image failed switch to recovery mode how do i go by fixing it
Build Type: -D
sumthing's really wron g with my sansa e280
when i turn the unit on the only display that i get is
Enter USB2.0 MSD mode
What now?
Help me please
Load Main imags failed
when i install the rockbox and reset the sansa say th loaded image failed
tengo problema, mi sandisk la reconoce windos como un harware desconocido y me pide los driver para poderla instalar, no me enciende tampoco su pantalla. ¿que debo hacer?
When i turn on it on it state that sumthin bout switch to recovery mode but dats da problemi dnt kno how to do dat dats y im here!!
stuck at refresh data bass
im in recovery mode and it says USB cable connected enter usb2.0 MSD mode what is that and how do i do this?
when the player is switched on the sandisk screen starts then a message
comes up stating " Load main image failed Switch to Recovery mode"
