I want to use my pentax digital cam as a webcam because of the better quality ..can I convert it to a webcam ?if yes how?
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
SOURCE: driver
Windows XP uses its own built-in drivers for digital cameras like your Optio 50. There is not driver for you to download.
With XP you should be able to simply open up the "My Computer" icon on your desktop.
Under "My Computer" you should see a "Removable Disk".
Double Click on it, and then your should see "DCIM", double click on that and then you will see "100PENTX".
Double click on "100PENTX" and you will see all your pictures.
You can then copy those pictures to anywhere on your computer.
If this does not work for you, you can always use a card reader to
download your pictures. Many later model computers have built-in SD
card readers. If your computer does not have a slot for an SD card you
can purchase a card reader, usually for under $20, at most major
computer/electronics equipment retailers.
SOURCE: Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
SOURCE: can i use metz 45 ct 1 with pentax k 20 d
The trigger voltage of Metz 45-CT1 Ser No above 534 000 are under7V, that is absolutely safe. But below this Ser No that can be anywhere around 200. This not necessarily means the flash will damage the camera, but consult the user's manual.
If you were intended to ask how to connect the flash to the K20 D, then you can use a hotshoe-to-PC adapter.
