" I'm searching the answer for my friend's audio problem,after hours using the pc's audio will not working itself and there's white changing colour on taskbar,all device drivers working properly on my check...i don't know whether its a virus or what?? the antivirus is up to date..i just help his audio problem with a new setup windows on his ASUS P5SD2-VM..and after installing all the drivers using the motherboard's cd,there's still 1 pci driver not installed..i don't understand it...and even the audio drivers is installed its still not working...i've search the updates driver if any in ASUS website and what they have is the same version..then another friend come to me with the same problem...i need a help on this so please help me!!! " (sorry for bad English)
You probably need Microsoft UAA drivers first
1) Remove any installed audio drivers through device manager
2) Download Microsoft UAA drivers for your O/S
3) Install them and reboot
4) go to device manager right click sound and update driver
It will go on the net and in most cases find and install them
Open device manager > system devices
Disable 'Microsoft UAA bus driver for high definition audio'
uninstall 'UAA bus driver'
Download :
motherboard_driver_audio_realtek_azalia.exe
You will find a link in google.
Extract, install, reboot and then your audio will work!!!!!!!!!!!
You may need to enable the volume bar.
Control Panel > Sounds and Audio
tick 'Place volume icon in the taskbar'
Install a windowes update (that update is alredy in your motherboard cd {in audio drivers file name is start from k****** } and then reinstall audio drivers its works.
If you do install the asus motherboard -p5sd2-vm audio driver through using the board cd-installer and still the audio is not working, then try to do this..
Step 1: Go to Control Panel>Sounds and Audio Devices then go to Audio tab.. check if the below of Sound Playback: Default Device "No Device Detected" are selected. if you can scroll the Sound Playback Default Device choice Realtek Audio Output and click the Apply button below .. and sure you there is now a sound coming out from your speaker.. if there's nothing to select then go to Step 2.
Step 2: Try to check in the BIOS if the HD Audio is Enable. Restart your computer and press the Delete key while your computer is booting.... by pressing Delete while your computer is booting you will be directed to your computer BIOS.. try not to do any kind of tricks in your BIOS okay..... Go to 2nd Menu Tab, then Chipset>Southbridge> check if the "onboard audio device" is Enable or Disable. turn the option Enable if it is Disable save your settings by pressing F10 key and follow Step 1. not included the last part. If the Onboard Audio Device is Enable proceed to Step 3.
Step 3: in this step i'm aware now that there is something wrong with your southbridge chip. It is the chip that controlled the devices like the Audio device to make sure of this awareness.. try this step. Go get a Sound Card if you have.. installed the sound card in your computer.. after you installed the sound card in your computer boot your computer and pressing the delete while booting... you will be directed to your computer bios.. now disable the Onboard Audio Devices.. follow the step in step 2 on how to disable and enable audio devices. after you disable the audio device save your settings by pressing F10 key. boot to windows normally and wait for the computer to detect the new installed hardware which that is the sound card... if the computer detected the sound card, then install the sound card driver and so on..... if the computer did not detect the newly installed Sound Card Device , then go to Contron Panel>System>Hardware tab> Device Manager button and look if there is an multimedia audio controller detected, if none then this is only one thing in my mind......your southbridge chipset which control the audio device got *******... the reason of this problem is factory defect or overheat of chipset due to over use .. in that case go step 4.
Step 4. Go buy a new motherboard with the same model or choose other model but compatible with your Processor, Memory, Hard Disk controller, Power Supply controller, cable connector and ports.
HOPE I CAN HELP
CLC
The PCI device that is not installed is Microsoft UAA Bus driver. right click my computer>manage>device manager>system devices and there you'll see PCI DEVICE with a yellow alert. right click it and select update driver then tick install the software automatically and click next. if this doesnt help download microsoft uaa bus driver and install it.
Microsoft UAA bus driver is needed in order to make your sound driver to work. This is needed in most of the latest motherboards. usually after installing the audio driver in the motherboard cd. microsoft uaa bus driver is copied automatically but is not installed automatically.. so u need to go to device management and run a update driver again. which gives a yellow alert which is called PCI Device
body {
background: #FFFFFF;
margin: 0px;
padding: 4px;
font-family: arial, verdana, sans-serif;
font-size: 10pt;
p {
margin:0px;
padding:0px;
.spwrap
background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
thanks a lot to both of u,colliewob and nicklen..i've found the
Microsoft UAA bus driver and installed it,but i got another stuck on
this "Files needed...the file 'hdaudbus.sys' on Microsoft UAA Bus
Driver for High Definition Audio. Installation Disk #1 is needed" and the driver is not fully installed..
please tell me what i need now? or i just need a link to download
another driver...
sorry for the accidently bad comment.. :-)
Allrights !!!....I GOT IT!!! its just a miss part,the file is already in the driver setup folder...thanks a lot to u guys nicklen n colliewob..very nice job..i'll come again for another future pc trouble,thanks to FixYa too,a simple looking site but great support to pc dummies... :-)
Audio is not working for P5SD2-VM motherboard... problem, and notify you when a new solution is offered.
when i install the service pack 2 in my system for Asus Mother board my Audio is not working.I can t understand simply it does not support.
same problem i tried uninstalling the microsoft AA.....and then tried to install the realtek but i still cant hear anything...but when i test it it seems to work fine....but when playing movies music i cant hear it and neither does itunes detect it...
Exactly the same problme but I cannot fix it :(
Do you have the same Problem?
Please describe the specifics of your problem below. We'll add your post as a comment to borhan_5113's "Audio is not working for P5SD2-VM motherboard..." problem, and notify you when a new solution is offered.
i bougt a new asus - p5sd2-vm motherboard around 20 days back. I am facing the problem in audio, actually i installed audio driver but still audio is not working, when i contacted one computer repair mechanic he told me to re-install my operating system, i reinstalled my operating system but it is still not working.
I have the same problem with p5sd2-vm motherboard . i am thinking of formatting my computer!!!!! But after formatting will it behave like as first ??help me!!( sorry for any mistake)
audio is nt working
My motherboard is asus P5SD2-VM. after installation audio driver did not show audio. solve it
Hi, i am facing some problem with audio driver.There are so many times try but i am not success.i am geeting error "closes.dll" erroe ,
please help me.ASAP.....................
NAME -RAJNI KANT
ID- [email protected]
i have still same problem please help me......
