Wont steer or turn by hand unless raised above steering bracket
SOURCE: I have the Minn Kota
if it is not steering with the remote - then the problem could be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
the best way to trouble shoot the unit would be to open the case and use volt meter to trace the voltage flow. also make sure you are getting power to and thru the remote as I have seen the control buttons go bad.
if you are still having troubles and have more questions - please feel free to write me back here and I will do my best to walk you through the steps needed to fix or trouble shoot more.
have a great night,
c...
ADJUSTMENT
Excessive belt tension will cause damage to the alternator and water pump pulley bearings, while, on the other hand, loose belt tension will produce slip and premature wear on the belt. Therefore, be sure to adjust the belt tension to the proper level.
To adjust the tension on a drive belt, loosen the adjusting bolt or fixing bolt locknut on the alternator, alternator bracket or tension pulley. Then move the alternator or turn the adjusting bolt to adjust belt tension. Once the desired value is reached, secure the bolt or locknut and recheck tension.
REMOVAL & INSTALLATION
1.5L, 1.6L, 1.8L, 2.0L and 2.4L Engines
Fig. Accessory V-belt routing-Mitsubishi 1.5L, 1.6L, 1.8L, 2.0L and 2.4L engines
Alternator Belt
Fig. Loosen the adjuster lock bolt . . .
Fig. . . . then remove the alternator belt from the engine
Fig. After the adjusting and fixed bolts are loosened, rotate the pump . . .
Fig. . . . then remove the power steering belt from the engine
Fig. Serpentine belt routing-Mitsubishi 3.0L engines (except 1998-00 Galant models)
Fig. Accessory V-belt routing-Mitsubishi 3.5L and 1998-00 3.0L SOHC Galant engines
ALTERNATOR AND A/C COMPRESSOR
the steering motor seems to be frozen, it will not turn with the remote or when I try to turn the motor by hand unless I pick it up above the locking ring. How can I check to see if it is rusted in place?
