I just replaced my lamp assembly and am getting the orange flashing light of doom...I just replaced my lamp assembly and am getting the orange flashing light of doom...
You can't post conmments that contain an email address.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Turning off and on pressing buttons does not work. Error 6000 means either paper is in the way. Try rolling the paper bar inside the printer to remove paper jam. Or, most likely the ink well, right hand side, needs cleaning .use toilet paper to remove excess ink in the ink well. Just recovered my printer doing this .
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work, First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
try this I know its a little annoying but its useful trust me. The orange light usually means a problem with the power supply. This means WORST CARE SCENARIO you have to replace the power brick but you 99% dont have to get a new xbox. http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/power.aspx cheers!
Is that something fixable?
