I have the same faucet and the same problem. I found that when I pull up on the gooseneck, I can feel it go back into position, but soon it falls down again. I'm also not sure if that part is accessible if it is taken apart.I have the same faucet and the same problem. I found that when I pull up on the gooseneck, I can feel it go back into position, but soon it falls down again. I'm also not sure if that part is accessible if it is taken apart.
AnonymousJun 08, 2017
Amercian Standard demanded a receipt from me. They stated they could not help me without it. They did convey that it's a design problem and not repairable. I'm sure that's true because I took the faucet apart as far as I could and was not able to do anything about it. Luckily, I get Home Depot to email the receipts to my account.Amercian Standard demanded a receipt from me. They stated they could not help me without it.
You can't post conmments that contain an email address.
Call AS at 800-442-1902, they il replace it free of charge, lifetime warranty. New design for replacement faucets, will not happen again, I didnt need to send receipt or anything, great people.
To open the unit, first remove the foil and cutters. Then remove the swivel frame by taking out the two tiny screws on each side. Then locate the two round screw covers on either side of the hole where th cord plugs into the shaver. You will have to pry them out with a tiny jewelers screwdriver or similar object. Then remove the two screws underneath. You can then carefully pry the case apart from the bottom
Yes, the water has to go further up hill sapping gravity, also the splash strainer is more efficient reducing the flow to prevent water splashing and filling the water stream with more air.
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore.
I suspect one of them has failed or come off during a severely unbalanced load.
try this
the washer needs to be leveled on a flat surface to properly function rock forwards then backwards
washing machine have stablizers on there leg pegs this insures it has a proper setting on floor
if this did not help there is a spring under neith that you did not load back to bucket to keep in place
most likely it just needs to be rocked you will know if pegs are seated properly
