The capacitor is a 30uf 250vac 60 hertz 5%toll with a temp range of -25 to 70 degree C
SOURCE: Has anyone at this site had much experience with a
You would be better off with a brand that has better representation than Grundfos. Several of our commercial customers change to brands such as Armstrong or Bell & Gossett the first chance they get because Grudfos is less reliable and getting parts or service on them much harder.
Testimonial: "Thank you for the info. It was appreciated."
SOURCE: grundfos mq3-45 pressure booster pump
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: Ok at the place I
Ok let me ask a few questions. 1.You said U have A 1HP Sub. It pumps from about 300'. How did U get this info? 2.Now the water goes into A 120 Gal storage Tank from the top,then goes out from the bottom. Is Tank A Plastic or Galvanized/PSI Tank. OK NOW.BASED ON THE INFO THAT U PROVIDED.ON THE ISSUES THAT U R HAVING. IT SOUNDS LIKE YOUR TANK IS WATER LOGGED. WHAT THAT MEANS IS.YOUR TANK IS FILLED TO THE TOP WITH ONLY WATER. SO THE ONLY TIME U GET PRESSURE IS WHEN THE PUMP TURNS ON. NOW TO FIX THIS WATER LOGGED TANK PROBLEM.ALL U NEED IS AIR. SEE WHEN THERE IS AIR IN THE TANK & THE PUMP TURNS ON. WATER GOES INTO THE TANK.IT COMPRESS THE AIR WITCH CREATES PSI. Let me ask u another question. By any chance,before this booster pump was installed.Have U noticed your system turning on & off rapidly.Like all the time.How about your power bill.Has it been kind of high.
I found a capacitor and replaced it, worked for 1 day and blew the capacitor again. something wrong with the control board or switches calling the capacitor to start the motor and keeps blowing the capacitor. decided to buy a new pump and install that. thanks for everyones advice!
