Computers & Internet Logo
Posted on Nov 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Colour corecting I have a problem with colour correcting my photos and I use adobe elemts 5 . I use levels and some times I use auto correction.when I print some they have a castON BLCK SUITS still in them when I click on auto cast. WHAT AM I DOING WRONG.
Edward Easley
Level 2:
  • Expert 97 Answers
  • Posted on Nov 28, 2008
Edward Easley
Expert
Level 2:
Answers
97
Questions
0
Helped
34551
Points
186
Hello there. Please visit forums at adobe.com
2answers
Cant get my 94 toyota camry to go into gear
ChecK fluid level with engine idling in park (auto fluid).
3helpful
5answers
How to edit picture?
Hi
You don't say which operating system you are using.
Photo Editing requires Photo Editing Software.
To do basic photo editing (cropping, rotating, flipping, adjust brightness, adjust contrast, adjust image size, adjust colo(u)r, adjust exposure, adjust size, adjust red eye) you can use free, built-in software that comes bundled with Windows and Microsoft Office such as: Paint, Microsoft Picture Viewer and Windows Photo Gallery.
In increasing order of editing functions:
Windows Photo Gallery: Fix > Auto Adjust, Adjust Exposure, Adjust Colour, Crop Picture, Fix Red Eye
Microsoft Office Picture Viewer: Picture > Brightness & Contrast, Colour, Crop, Rotate, Flip, Red Eye Removal, Resize, Compress.
Paint: Image > Flip/Rotate, Resize/Skew, Crop, Invert Colours, Adjust Attributes, Clear Image, Opaque.
In Paint you can also use additional tools to manipulate the image or add or delete shapes, text and colour (with a selection of writing or drawing implements): Free Form Select, Select, Fill with Colour, Magnifier, Brush, Text, Curve, Polygon, Rounded Rectangle, Ellipse, Rectangle, Line, Airbrush, Pencil, Pick Colour, Eraser/Colour Eraser.
In Windows Photo Gallery you can view and edit the same image in either of these 3 programs by clicking Open.
For more advanced photo editing, you can use the bundled software that comes with digital cameras such as:
Adobe Photoshop Elements
ACDSee
Picasa
Photo Studio
For more advanced, professional standard photo editing you must buy expensive Photo Ediiting and Graphic Design software such as:
Adobe Photoshop
Adobe LightRoom
Adobe Illustrator
Adobe InDesign
CorelDRAW
Corel Painter
I hope this helps.
I have problem with Aficio 220 Ricoh Japan machine and fault is like this SC541 (Fusing thermistor open A level) please help me. my email is [email protected]
Verify your fusing lamp or thermofuse and replace it if necessary
If your circuit is correct, replace the power supply unit
Don't forget reset code :
Enter SP 5-810 (SC code
reset) and select "1". Then hold
down the Photo mode key and
the 7 key at the same time for
at least 3 seconds (this does
not require the main switch to
be turned off and on).
Hi there!! I stop using my cam for some months. When I tried to use it again, The video recording or picture shot didn't work correctly, it seems like the lights were off. Everything look dark. The rest of...
1. Dear client! 1st you run the adobe photoshop and then browse these all pictures in adobe photo shop then press Ctrl+M now adjust the photo brightness in other color.
2. For Movie colour setting 1st you download VLC media player. Then install this media player in your computer and then press (Show extended setting) then go to (Video Effects) now you adjust your brightness of your movie.
2answers
Can't print photos with correct colours. Photos in .jpg format and I know colours on screen match colours when printed commercially. Printing from Zoom Browser or Canon Easy Photo gives much worse results...
First clean the print head and run the test print and then the alignment setup to make sure that the printer is clean and registers correctly. In the Printer Properties (Right click on the printer name via Control Panel - Printers) there is an option tab for Colour Management. Click this and select the source that you need to match the print output to. Also go through all the other tabs in Pinter - Properties as there are many setup options there to setup and tweak the colour balance and adding effects etc. This can be quite a lengthy process but well worth the effort. There is no shortcut to doing this but you will end up with a precisely calibrated custom printer setup that you can save and reuse at any time. I have these profiles defined for my printers for each media type and each ink supplier although I have minimised the number of profiles by now using 1 bulk ink supplier to get consistency between cartridge changes and CISS refills. Note that this may vary when you change print carts or change the media type and manufacturers.
2helpful
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
1helpful
2answers
Auto Correct option is not working in all MS Office Versions
When you install Microsoft Office, AutoCorrect is set by default to try to match and correct a misspelled word with a word in the main dictionary that the spelling checker uses. However, if you want to make sure this option is enabled.
Do this is Microsoft Word:
  • Click the Microsoft Office Button
  • Click Proofing.
  • Click AutoCorrect Options
  • On the AutoCorrect tab, select the Automatically use suggestions from the spelling checker check box.
2answers
CHange a colour
Please mail ur photo to my email id [email protected], and explain ur problem in much more detail. i'll fix it and mail u the corrected photo back to u.
4answers
Problem
image ready is basically a web desing program for designing web pages and web base graphics GIF'S etc
Photo printing
if you have adobe photoshop click on image - selective colour- set the following cyan +15 magenta -5 yellow +10 black-15 this works on the pixma ip8500 so there is every chance it will work on others
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
