I need help to pair the Uniden handsets up to my Optus wireless home ph HUAWEI F685. Can you please help me? I cannot afford to be charged any $$ for this solution.Thanku for your help if u can help me. The uniden handsets read "check TEL line" .
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
SOURCE: Need English documentation for Uniden Sireus 5080 phone & 0500 handsets
Here is the solution I found.
I also bought this equipment and also didn't find anything suitable in the internet, BUT a phonecall to the suplier EUROCOM brought the solution.
I called their service nr. 03-9029000 and got the English user manual as a PDF doc. by email.
Yssachar
SOURCE: How to turn off telephone ringer on handset for
Just press the down arrow on the center button
SOURCE: uniden dect 6.0 display reads searching
Hi there, try this. Press and hold th eend key on one of the handsets, while holding the end key, press and hold the # key. After 3 or 4 seconds tha thandset should beep and read deregister Handset and underneath that "Base Unavailible". Select base aunavailible and confirm. Then tha thandset should read "Handset not registered, place handset on base" Once you place the handset in the bace cralde it should register in 5 - 10 seconds or so. then you should be good to go.
Both uniden handsets are fully charged & read "check TEL line", I need help on how to pair up these handsets to my optus wireless home phone handset. Please help me.
Its not a mobile phone, but a cordless wireless home ph. Its to pair up with my optus wireless home ph, so i have the usage of more than just 1 handset. The optus home ph is situated in my kitchen, but im tryn to hook up the uniden DECT 3035+1 handsets home ph paired/linked up 2 my optus home ph. I want 1 uniden handset in my loungeroom & the other handset in my bedroom. If anybdy out there can help me set it up to work on all 3 handsets- u can ph me on my mobile number 0403466986 @ 4pm on tues 5th june & wed 6th june..... Please help advise me if u can....................
Unfortunately the handset I was advised to get (Uniden DECT 3035) to pair up with my optus wireless home ph did not work out. I got in touch with the Uniden Support Hotline after Optus told me of a another uniden handset that can be paired with my optus handset. I have oredered it directly from Uniden. The handset is a Uniden DECT 3005. Fingers crossed it will work this time. It'll take up to 10 working days for me to recieve the uniden handsets in the mail ..... il keep ya posted guys @ FixYa :)
THERE ARE NO HANDSETS THAT ARE COMPATABLE TO PAIR UP WITH THE WIRELESS OPTUS HOME PHONE HANDSET F685 HUAWEI , so ive just got to be greatful with the use of one phone until optus eventually brings in a 2nd handset that is compatable! ........ :-( .............
turn off silent mode f685 Huawei phone
remove silent mode f685 Huawei phone
