In server 2008 with standard tcp/ip port
SOURCE: useing Linksys wpsm54g with tcp/ip
that will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
SOURCE: hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
SOURCE: D-Link DP-300U Print Server Problem:
So... you've messed up the IP address on your DP-300U and now you can't even access the web browser configuration page? Yes, it's happened to the best of us. Although I'm sure there are more elegant solutions, one fix is to reset the server to its factory settings and then reconfigure it from scratch. Given that there is no reset button on the DP-300U, resetting can be frustrating, especially if it's asking you for a password that you never created in the first place! Here's what you can do...
1) Install the psadmin software which came with the print server. If you lost the software, you should be able to find it on the web somewhere.
2) Start the software. It should automatically locate your print server.
3) Click on "factory reset". If it demands a password, and you don't know it, try "SYSxxxx" (where xxxx is the last four digits of the MAC address written on the underside of your server)
4) Dust off your Quick Install Guide and go through the unintuitive configuration process. If you no longer have your Quick Install Guide you can find it on D-Link's website.
SOURCE: I have window 7 64bit
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
