Question about Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 and the standby light blinks twice and makes a click noise and a bang sounds off in the back of the TV and then it repeats its self , the TV does not turn on .
TV won't turn on , Standby light blinks twice and then there is a click noise and after that a loud bang then the process starts all over again , this is constant non stop . I don't try to turn on the TV cause the bang noise might cause the TV not to work ever again !
  • 1 more comment
  • Mike Lafontaine
    Mike Lafontaine Jun 02, 2012
    Did it bang just once, or every time? If just once, then a capacitor or fuse (unlikely) blew. If it bangs every time, hmmm.....
  • rick burkett Jun 02, 2012
    Yes , there is a loud bang noise after the light blinks twice then a click noise then the loud bang . this is non stop I have to unplug the TV from the wall outlet in order for it to stop , also if I plug the TV back in to the wall outlet the process starts all over again and I don't even have to turn the TV on !
    I did have a TV repair man come to my house and he checked the TV with meters and he said it was the Q-Block , does this make sense to you ?
    Top Expert:
  • Sony Master
  • 76,204 Answers
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
    Pull up older posts. You can get all details.
    Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
    Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Posted on Jun 02, 2012
2 Suggested Answers
6ya staff
SOURCE:
gopakumarg43
  • 76204 Answers
SOURCE: standby light blinks twice approx every 2-3 seconds tv won't turn on
Visit this site 'Electro-help" for details. Type in the site name either to Google or Yahoo search box, and click search. It has all details about tthis fault, and repair.
Posted on May 12, 2012
Engineer seeks help with no-picture, no-sound, normal standby blinking
Could just be a power issue. I have not done much with CRT televisions except smash them to bits. I would open it up and try and look for anything obvious. Since it is taking so long to come on, I am wandering if there is a cap that is failing. It will be hard to know if there is no visual evidence of failure, and the only true way to measure is with an ESR meter.
Apr 24, 2013 | Sony Fd Trinitron Wega Kd-34xbr960 34 in....
Kd-34xbr960 doesnt come on
Count the number of blinks of standby light at one time after switch ON. Count it once more and make sure that the out is correct. These blinks are fault indications. Check this link to get more details about the blinking codes to Sony Trinitron TVs. Details are there. You can locate the faulty section by these blinkings. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 11, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony XBR400. The 40
The standby light shouldbe blinking is a pattern of a count followed by a pause then the count again repeatedly. If you can post that count here, we can use that to indicate the circiut in which the problem exists. That will determine the probable cost to repair.
Thanks
DAn
Feb 08, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Sep 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
