SOURCE: REPLACE FORD TAURUS WAGON DRIVER SIDE MIRROR
you have to take the door panels off. remove all screws you will have plastic pieces called christmas trees that hold the panel in place. there is a tool for this you can pick it up at Napa for cheap this will allow you access to the inner space of the door un plug plugs to power switchs and the rod to your door catch hardeware you then can remove panel completely to get access to mirror assembly. installation of door panel is in reverse
SOURCE: Ford Expedition 2002 Front Heater blows cold air below 45 MPH
impeller is made of plastic on teh water pump and its slipping and spinning on the shaft renew before weather warms up as engine will overheat
SOURCE: Ford taurus 94 start problems
check fuel filter and make sure fuel pump is working. replace as nessasary.
SOURCE: steering wheel shakes when driving at high speeds between 45-60 m
Have frount end alligned, balance tires, check ball joints, tie rods.
SOURCE: Adjust (aim) headlights on a 1990 Ford Taurus
The adjustment screws/nuts should be located either on the top of the headlamp assembly,
behind the headlamp assembly, or near the frame rail by the radiator
support.
You will have vertical adjustment screws for each independent beam
(separate highs and separate lows, but will be same screw if highs and
lows are the same bulb). You may also have additional horizontal
adjustment screws as well
Park
your car on a level ground 30 feet from a wall and measure the height
from the ground to the bulb and mark on a wall (do this for highs beams
and low beams if the bulbs are separate, if highs and lows are the same
bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then
aim the brightest part or cutoff part just below the mark on the wall.
If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
