In trying to connect my new VHS/DVD player, I somehow switched the channel for playback, and because my remote doesn't work, I can't find a way to fix it.
A universal remote can be set with this TV. Select one universal remote control, which has setup codes for your TV brand. For more details about codes and setup proceedings,
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments. Pull up older posts. You can get all details. Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page. Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
SOURCE: input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV. If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
