I shot the sun during one recording and now have what looks like a round blue flare/spot on all my images. I heard there is a way to repair this with some secret sub menu only JVC knows about. Has anyone else had this problem with their JVC GY-HD 100 camera and knows how to repair it?
SOURCE: Can't get rid of the screen images for video camera on playback
Hi
If it's like my Canon MVX25i date and time marking then go to the menu, select display setup (or whatever it's called on your camera) somewhere there should be a dialogue which allows you to switch the pesky thing off. I have never used date or time, a very amateurish concept in the first place.
Redars
Scorpigirl
SOURCE: JVC GY-HD110U won't turn on with battery power only AC power.
There is an issue with the a small yellow part of the AC plug breaking off in the camera. The camera thinks it's still plugged in, so it won't run on the battery. If you can get a small tool to fit into the inlet you can break the piece up and pull the parts out. I haven't had any luck with it, but read others doing it.
SOURCE: ro record, and no image in the screen on the camera JVC GZ-MG50E
I answered same problem like you have now. Just in case you don't find it. I hope you are familiar with these things technically. Open the set up-to where the lens can be accessed, remove the iris unit and clean those two curtain(shutter), for sure it's stucked up. You san test it by moving it open manually and it must close when released. To clean, you have to remove these curtain out from the assy. Spray with head cleaning agent or any alcohol base cleaner and dry.Test iris unit first to make sure its ok before assembling. Good Luck
SOURCE: converting
I would like to share you a best converter i have used:
Video Download Studio
Click here to see the full reviews and have a free trial:
http://www.downloadvideos-convert.com/download-videos-music
It can convert almost any the video format to another with high output quality.
This full-featured video converter software also can help you:
1.convert between all mainstream video and audio formats,such as(mp4, mov, m4v, vob, XviD, avi, flv, 3gp, 3g2, mpg,wmv,etc;m4v, mp3, wav, ac3,etc)
2.extract audio tracks from video files to other audio formats
3.support all popular portable multimedia players
4.edit video-Merge, Trim, Crop and Snapshot
It is very easy to use,just follow the instructions on it you can convert your videos and make your movies and music taken easily on PSP, PS3, iPod, iPhone, Apple TV, Xbox or other digital devices.
Hope this can help you.
You have probably burnt out the sensor
