Drill works fine but I can't get the torque collar to turn beyond 21 to the drill or hammer settings.
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
SOURCE: My DC 925, is destroying
sounds like there may be a short somewhere. Don't use it like this as overheating the batteries will ruin them. and they cost almost as much as the drill
I am assuming you are talking about
not being able to move the "Mode Control Collar" and unless you can
get it out of hammer mode, you will not be able to change the torque collar
either.
If you feel comfortable taking it
apart AND its no longer under warranty, my best guess without seeing the tool will
be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so
you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Took the gear module off and set the drill to hammer. Put everything back together OK, but when I turned to 21, it wouldn't go back to drill or hammer. Took it apart again, set it to hammer and re-assembled. Works on drill and hammer ok, so I won't be using the numbered settings again.
