Access violation at address 0044C591 in module 'Veo DigitalStudio EXE'
Read in address 00FAAAC.
I reinstalled the program with my disc. It didn't correct the problem so then I downloaded new drivers and it still doesn't work.
Please advise
Thank you
Bob
1st You download Webcam Driver.
Message Access violation at address 0044C591
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: VEO Camera trouble
have you tried to update the drivers and program that came with camera as this is always the way with programs they run on early versions of windws and not properly on yours. hope you can sort this out
SOURCE: Veo webcam problems
I am using skype and I cant use my cam, it keep saying that i need to disconnect all other programs that are using the a video. Can someone help me
SOURCE: veo advanced
Oh for goodness sake why cant the message read "you broke it .... throw it away and get a new one" ?? At least u would understand that !!!!!!!!!!
SOURCE: receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
