I changed the batteries in my skyscan clock and skyscan outside temperature transmitter 433MHz, now the outside temperature does not work. I went through the recomended procedure several times. Still does not work. What now? Anyway to check for the problem?
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
I have tried the multiple ways to get the temp to work. It works intermittently. Any other ideas?
will not show outside temperqture
