CAN'T CHANGE DATE
SOURCE: having power problem
Let just make sure we do the simple things first
check the batteries and make sure they are in the right way . then we will go from there
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
SOURCE: reset date/time stamp
Here is the only information I could find for you. This is a link to the extended user manual. You want to look in two different places. The 1st place to look is "setting up your camera". From there there is a heading for setting up the date and time and language. The 2nd place would be "Doing more with your camera"
http://www.kodak.com/global/en/service/publications/urg00846toc.jhtml?pq-path=12649/12701
Hope this helps.
SOURCE: kodak ZD710 when I turn the camera on the only
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
