We didn't get a manual with our thermostst
Your first problem is the AEV1000 come with a Dehumidistat on not a Thermostat.
Best place in Summer time is 90% or unplug the unit if you open your windows.
Best place in winter time is around 40%-50%
For the manual. contact Fantech at 1-800-565-3548 ask them for the 1 or 2 page manual for MDEH1 They can email it to you of Fax it. They can probably even Mail it.
Energystar says to keep it within 4 degrees to save the most money, for instance, if you want the cooling to be 72 when home, dont go more than 76 while away, you spend more money trying to recover from high temps. on the flip side, if you like it 68 in the winter, dont set it less than 64 when away! that should help
You put too much verbiage in the subject line so your question is truncated.
Thermostats by definition control temperature so regardless whether it is marked 1-10 or in degrees, you need to set it for your comfort and it will turn off and on to try to regulate it.
