I recorded a video and i would like to put on to the laptop but it wont let me i have tried doing it via the camcorder, sd card and using a different laptop but nothing seems to work.
SOURCE: how do i put a tape recording onto the pc?
dg9dotorg is correct about the memory card. The memory card and USB cable can be used to transfer still images only. To transfer the video you need a DV cable (also called a Firewire cable).
If your PC is relatively new it most likely has a firewire port. If it does not then you'll need to purchase a firewire card.
You will also need software to capture the video. I use Scenalyzer. You can download a demo version of this software at no charge. The link is http://www.scenalyzer.com/
The demo version is fully functional, but it will put a watermark on your video.
Good luck.
SOURCE: cant record video on memory card
im trowin dat videocamera to da garbish its bullshyt.people dont buy those dey r caca lol.
SOURCE: I have a used GR-D270U JVC camcorder, can't record w/it?
Open your view finder screen. There is a button there that says video/memory. push it down to the memory. The record button is at the back to the upper right of the battery. Hope this helps.
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
