Sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
