Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer rec is blinking how do i shut it off
Power dont come on.
Anonymous
Level 3:
Top Expert:
  • Toshiba Master 14,553 Answers
  • Posted on May 31, 2012
Anonymous
Toshiba Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715253
Points
48227
Blinking light means set is in shutdown.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
timer rec is blinking how do i shut it off - 5_31_2012_5_07_35_pm.jpg5_31_2012_5_07_51_pm.jpg
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jan 11, 2011
SOURCE: The power went out and
contact toshiba and ask them for sencor for the remote
Timer blinking
Turning the record timer on/off
  1. 1 Press TIMER/CLOCK ADJ.
  2. 2 Use the <> (cursor left/right)
buttons to select REC.
On the front panel use '<<>> and <<>>'
  1. 3 Press ENTER.
  2. 4 Use the <>(cursor left/right)
buttons to select ON or OFF.
5Press ENTER.
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
1helpful
I dont know how to set the camera up so I can take pics of myself without holding it.
In the REC mode, press [MENU]. On the "REC" tab, select "Self-timer" and then press right. Use up/down to select the timer type and press [SET]. To start the self-timer, press the shutter release button.
TV acts like it is turning on then shuts off then repeat, repeat
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
3helpful
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
I recently moved my toshiba 62mx195 across country it was well wrapped in bubble wrap and moving blankets, Now we go to turn it on and nuthinghappens except the timer/rec blinks yellow then the power blue...
Your Tv power supply is in protection, this means it wont start up, could be static. Rather take this to a Service Centre to check, If you have insurance claim it under the section travel/moving goods etc
2answers
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
