Question about Sirius Satellite Radio Receiver
Audi A4 cabriolet (factory installed) Sirius radio antenna aparently shorts out
Sirius radio plays well untill I turn radio off...when I turn it back on later, Sirius doesn't play...it may come back on later on, and as long as I don't turn radio off, it plays o.k. Dealer says that he has to remove the convertible top in order to fix antenna...$1,200!!!!
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 20 Answers
SOURCE: Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Posted on Apr 27, 2008
MrScary66613
Travis Humphries
  • 1990 Answers
SOURCE: Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
Posted on Jan 01, 2009
sierratrout
SOURCE: I have a 2009 Dodge Ram pickup with factory sirius
We had the same issue with our 2007 Dodge Ram truck. We use an external antenna when we have the camper on. You can buy these at various places on line. Get the car antenna not the home antenna. It magnetically mounts onto the truck so we put it on our hood and routed the antenna wire through the passenger side door. Our satellite box is behind the glove box. Remove the glove box and look up in the cavity. We were able to just unplug the factory antenna and plug the external antenna in. It's easy to switch back too. Just be careful with the antenna wire because it's fragile and any little bit of damage makes it useless.
Posted on Jan 28, 2011
Engine noise through sirius
First check fo good ground on lighter socket sometimes manufacture's use whats called a floating ground which is one wire connecting every socket for a ground . This creates what is called a ground loop and can create noise. Instead of rewiring try an inline noise filter. check with your local car audio store. Hope this helps. If not write back.
May 06, 2010 | Sirius Satellite Radio sp-tk2 Satellite...
Unit keeps beeping and turning itself on and off. Have had this radio for 5 years and never a problem until now.
Hi sasutton,
SIRIUS-Ready radios are usually identified by the SIRIUS dog symbol appearing somewhere on the radio itself. A SIRIUS-Ready radio is a radio that may require the purchase of a SIRIUS tuner in order to be activated.
Every 90 minutes if you do not interact with the player, player display a notice and play a small audible alert to ask if you're still listening to the player. If you're not, the player will shut down after five minutes of the message being up there. If you are there, all you have to do is click the button and you can continue listening. Sirius player do this so that we're not streaming to computers that have no listeners, to maintain optimum performance for active listeners. You are probably not sitting at your computer when this message pops open which is why you get interrupted.
And Thanks.
Mar 19, 2010 | Kenwood Here2Everywhere SIRIUS Radio...
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Mar 28, 2009 | Xact Communication XTR1 SIRIUS Radio...
Nov 25, 2008 | Sirius Satellite Radio Receiver
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
S50 will not play audio for MP3, or stored songs
Visit here: read the whole page top to bottom...
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=601930&catParentID=7874&scId=7874&oldParentID=7870
Note: This product is no longer available for purchase. It is presented here for access to support documentation, software and related accessories only.
It sounds like you are having a software programming problem and may need to return it wma capble features may be corrupt.
May 01, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius s50 problems
Remove battery for 10 seconds and re-try.
Jan 15, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius S50 buttons
bring back to the store broken product
Dec 19, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Satellite Radio Receiver Logo
95 people viewed this question
Top Sirius Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Anthony Ward
Anthony Ward
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
