My router is working fine with laptops and iphones.I am using d-link router dsl 2730U.When I scan for wifi in my Blackberry,it connects to the router and shows as connected(i.e it accepts the ssid and password (WPA2)).But when I try to browse on my phone,It shows message as unable to connect to data service,Contact your service provider.
SOURCE: black berry bold unable to connect to data services while roaming
It might be worth looking at whatever plans you have. When you unlock your blackberry it still needs a sim card from some provider. When you unlocked and put in your new simcard, you bought some sort pf alternate phone/ Data plan did yopu ask for a mpa of areas that your nwe plan works from? They usually have a map of coverage that will show you if you had coverage in mexico. If not then it has nothing to do with the unlock it has to do with whatever provider you use doesnt servoce the area. Then tyhe answer is to get yuet another sim vcard with another plabn that works there. . Addtionally depending on where your blackberry came fromm it simplymay not puick up the proper frequencies as phones in meixco use,.. I know people who got their unlocked decvice from the middle east or africa or south america and those devices simply don't use the same frquency as the US or Canada does. If your device was orignally from Rogers then if you have no probnlem with getting services to work in the US or canada or even the US virgin islands which Roghrs does cover but at an astoundingly high Calling and Data rate ( like $1.35 Per minute vouice and .35 cents per KB in the carribean .. then it might just be the phones settingts which RIM puits in depending on whare they intend to have the device sold ..they seell worldwqide so if your fivice was designed fo Asia it simnply might not use the bsame frequency as US or candain devices
Check the coverage map of whatever planyou have from whatevber alternate provider your going wiyh ..you had to get another sim cartd to get the devie working. That sim card has to be attched to some sort of data and voice plan. check the coverage and then look into where you bought your blackberry and whre yuour tring to use it from . if it's rogers check and see if the devioce itself wll work in Mexico ..it just might not. Riogeers isn't really interested in making it easy for you to use servoces from far awat. Theres no compitition and as small population. They don;t have to do anything more then possible, I have had a regular cell from Riogersa that worked throughout the carribean..but nbot in othr arteas at all. . I have a blackberry noi but I have another friend who went deeply into brazil and other areas and while devices locally bought( even smart phiones) worked. Devices bought in North America don't work in some countries. It;s like DVD encoding. If you buy a DVD that is coded for the Middle east it won"t play on your DVD thats supposed to be for use in North ameica. Smart phones have some simiolar restrictions locked or unlocked ,
SOURCE: No service
try removing the battery and putting it back in.
that will complete reboot the phone.
SOURCE: WIFI
connect to wifi using my blackberry curve 8520
1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Testimonial: "Thank you for your swift reply.I can now connect but I still have a minus sign in manage connections? Under uma connection shows a cross? "
SOURCE: connected to wifi but cant browse internet
Solution:-
Disconnect from all connected network & then Reconnect to wi -fi.
Restart & configure your Wi-Fi- Router.
Thanks.
Happy to help you.
