SOURCE: Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
SOURCE: Bobbin winder will not turn..
Without knowing what type of machine you have its hard to determine if the problem is mechanical or electronic. If the bobbinwinder has its own motor than its probably electronic and it could be a bad motor or circuitboard. Sounds like this could be it.
The minimum service charge could be about 50.00 but this won't include the more expensive part. You might look up Sidewinder bobbinwinders which is a small separate unit you can purchase in most fabric stores or online for about 20.00 and just wind bobbins separate from the machine.
Good luck.
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
