Not sure of model # we bought it clearenced because of scratches did not come with mannuel
SOURCE: washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
SOURCE: my GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
SOURCE: ATF6000FS1 Frigidare front load washer The
Suggests that motor not not tuning heavy loads due to worn belt or motor.. you could check if Carbon Brushes are worn if they are fitted some motors dont use them..good luck
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
