Canon Pixma Mg5220 Inkjet Multifunction Printer - Color Photo Print Logo
Posted on May 30, 2012
Reset ink tank canon pixma 5220 - Canon Pixma Mg5220 Inkjet Multifunction Printer - Color Photo Print
5 Related Answers
billveik
  • Posted on Apr 07, 2008
SOURCE: pixma 500 - Ink Tank 'Not Recognized"
carefully remove the tanks from the print head cartridge. use a q-tip lightly soaked in isopropyl alcohol, or use a q-tip paired with an alcohol prep pad from a first aid kit.
gently rub the rubber seating areas for each tank, removing the dried ink from the rubber seat. swab the soaked q-tip, or use the q-tip to gently press the alcohol prep pad into the rubber stopper. use a different spot on the q-tip or pad for each one.
check the print head for ink stains on the black plastic, clean those as well.
Use canned air to dry the stoppers, replace the tanks, and check status. Print a test page and check results.
If you do not print many items, you can avoid the situation by printing a test page every once in a while to keep the contacts clear. Also, run the program to clean the print heads occasionally, and always turn the printer power off at the printer (that seats the tanks down on the stopper, helping to prevent the contact getting plugged by dry ink.
A
Anonymous
  • Posted on May 01, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Anonymous
  • Posted on Nov 20, 2008
SOURCE: Reset Ink Tank for Canon IPF 610
How do you reset the waste ink tank on the IPF700? Would appreciate it if someone could help me.
Thanks
Anonymous
  • Posted on Oct 27, 2009
SOURCE: How do you reset ink levels on a Canon pixma mp190 printer?
you can reset low ink error by pressing stop/reset button for 10 seconds
Anonymous
  • 352 Answers
  • Posted on Jan 27, 2010
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
1helpful
2answers
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
2answers
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
1helpful
Empty the overflo ink tank on a canon ip5000 printer
The waste ink absorbers on a Canon are pads that are under the print engine and cover the whole bottom. It is a major dissasembly where the covers come off, cables and plugs un plugged, power supply removed, and then you need a shop to reset the counters.
Canon MP620 ink tank out stalls entire printer
https://support.bchtechnologies.com/hc/en-us/articles/200701259-How-to-reset-Ink-level-Canon-30-241-PIXMA-iP-MP-MX-MG-Series
1helpful
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
5helpful
2answers
Where is the waste catrage in the PIXMA iP3000
Try this solution to reset the ink tank , it should work for most pixmas and several other Canon printers.
http://www.fixya.com/support/t538192-waste_ink_almost_full
4helpful
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
6helpful
3answers
Pixma IP4500 Ink Tank Reset
GET ON TO YOUR GOV' REP AND KICK UP A STINK.
PEOPLE POWER. HEARD OF IT . DON'T EVER FORGET IT .
PETER
old marine
old marine
ZJ Limited
ZJ Limited
