Cars & Trucks Logo
Graham Yeo Posted on May 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 1198 bmw 318i compact is only sparking on 1&3 cylinder
Ben Darden
Level 3:
  • Master 984 Answers
  • Posted on May 30, 2012
Ben Darden
Master
Level 3:
Answers
984
Questions
0
Helped
313414
Points
3004
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
I recommend a diagnostic scan to confirm my diagnosis of a malfunctioning coil(s).
How to Test and Replace Ignition Coil on BMW 3 Series
The following procedures apply for BMW 3 series (6-cylinders engine) 1992 - 1998 model years. To Test and Replace the Ignition Coil, do the following:
  1. Remove plastic engine covers from top of engine by prying off nut covers and removing cover mounting nuts.
  2. Disconnect harness connector from coil. Connect multimeter between terminal 15 (+) in connector and ground. (use a digital multimeter for the following test). See Fig.1. below BMW 3 series coil harness
  3. Turn ignition on and check for battery voltage. If battery voltage is not present, check wire between terminal 15 and ignition switch. The wiring to terminal 15 (+) of the coil (via the ignition switch) is not fuse protected. Use care when testing this circuit.
  4. Turn ignition off.
  5. Use a multimeter to test coil primary resistance at coil terminals. (primary coil terminals: 1 (-) and 15 (+), primary coil resistance: 0.4-0 .8 ohms; secondary coil terminal and resistance: NA).
  6. Remove coil and inspect coil housing for hairline cracks or leaking casting material . A leaky ignition coil may indicate a faulty engine control module (ECM). Check ECM before installing a new coil.
  7. When replacing ignition coils, ensure that the replacement coil(s) are from the same manufacturer containing the same part code numbers. If individual coils with the correct specifications are not available, all coils should be replaced.
5 Related Answers
Anonymous
  • 149 Answers
  • Posted on Oct 27, 2008
SOURCE: how to get to spark plugs 1-2-3 cylinders on 4.2l Freestar minivan
usually u need to take apart parts inside the actual vehicle (in a van like that) like underneath the radio area..u could go to the library and borrow the chilton or haynes manual that will for sure tell u where all the screws/nuts/bolts are located to take the inside panels off
Anonymous
  • 16 Answers
  • Posted on Mar 12, 2009
SOURCE: replace ignition lock cylinder 1996 BMW 318i with 1995 BMW
no you can not
junmag
Jun Magno
  • 175 Answers
  • Posted on Jun 02, 2009
SOURCE: Need Fuse Map Diagram BMW 318i 1993
check the internet for a bmw e36 ETM ( electronic troubleshooting manual) everything you need is there.
Anonymous
  • 106 Answers
  • Posted on Jun 04, 2009
SOURCE: have no spark on the spark plug 318i bmw 1995
Rotor, cap, distributor, wires, etc...
bourge
  • 5 Answers
  • Posted on Jan 19, 2010
SOURCE: coge reading P0300. 3 &6 Cylinder has no
Did you solve this problem? I am having a rough time figuring this one out on my 99 Montero! Maybe the ignition control module (power unit) or an ECU problem? Please let us know if you have solved it! Thanks
What does code p0203 mean for bmw 318i
Nr 3 injector faulty or open circuit to nr 3 injector. You could swap injector to another cylinder, clear the code & see if the code changes to another cylinder (PO201 nr 1, PO202 nr2 etc) then you know the injector is faulty or you could just replace & clear & see how you go. Most likly cause is the injector.
I nee the firing order for a bmw 138i 1993
I'm going to guess you meant a 1993 BMW 318i just because...
The four cylinder order is 1-3-4-2. Sixes are 1-5-3-6-2-4.
Car misfire BMW 318i automatic 2002 model
can you tell which cylinder is affected? If a spark plug gap is to wide, the coil may have trouble creating a hot enough spark to jump it. Check your plugs for proper gaps befor looking to the coil. Good Luck _Ned_
No spark on # 1 cylinder and weak spark on # 3 cylinder.
check the multiplug connections on the dme control unit in the e-box in the engine bay on the right hand side as it has been known that corrosion can damage the pins
2helpful
2answers
Head bolt touqe settings
Tightening torques
Do not reuse the bolts as they may be stretched.
Cylinder head to engine block
Stage 1: 32Ft-lbs
Stage 2: +90degrees
Stage 3: +90degrees
Cylinder head to lower timing
chain cover: 89in-lbs
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
