Camera hasn't been dropped or submerged in water. Date keeps going back to factory setting. Changed internal battery and camera worked once. After that, it opens and display goes blank and E 24 appears on screen. Date reverts back to factory pre-set.
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
SOURCE: Blank LCD screen
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
SOURCE: dark view field
This camera has been recalled and will be repaired free of charge regardless of the warranty status.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9739&keycode=2112&id=48266
I don't understand the suggested answer (solution 1) by binay biswas
