GE Advantium 120 Convection/Microwave Oven Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan comes on randomly.
Sometimes when the microwave is not even turned on. Usually for just a few seconds. Oven is about a month old.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 338 Answers
  • Posted on Nov 27, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
338
Questions
7
Helped
126644
Points
796
Alot of newer microwaves have a feature that if you are cooking on your stove and the bottom of the microwave gets hot it will turn the fan on to help protect the microwave. if thats not the case the you could have a faulty control
4helpful
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
10helpful
3answers
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
1helpful
Goldstar model mv1526.Sometimes the fan comes on by itself and the only way to stop it is to unplug it for a few hours. The fan off on button does not stop it even though it reads fan stop.
Contact the manufacturer (Goldstar) about that--it sounds like your microwave definitely needs to be repaired, especially since you've already tried unplugging it (which is the first thing a technician would suggest that you try). Usually, the manufacturer can tell you how to get your microwave repaired or replaced, and if it's still under warranty, the repair/replacement may even be free!
Goldstar's phone number (according to their website, www.goldstarappliances.com ) is (800) 243-0000
Good luck! :)
5helpful
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
1helpful
2answers
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Sensor error and periodic beeping for Advantium 120
If the internal cooling fan does not come on when you're microwaving, the magnetron will overheat and the thermal cutout will be tripped, causing the oven to go dead until it cools back down.
If this happens more than a few times, the magnetron can be damaged.
If the turntable is not turning (assuming it's not set to be off) when you're microwaving, then the problem lies on the relay circuit board (sub PC).
If the turntable is wokring and the fan is not, then the fan motor or wiring is at fault.
At this point, with such odd problems, I recommend that you contact GE customer service for your nearest GE-authorized service center
GE Customer Service is here.
Good luck.
MICROWAVE
First of all, it Roper may honor the warranty even though you're not the original owner. I'd contact them first: http://www.roperappliances.com/support/
If they won't cover it, here are some tips:
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
This last issue is what I suspect in your case.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We appreciate your thoughtful rating of our answer.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
