Aloha and Mahalo for the efforts! Up to now, no problems at all with my flashdrive. Then today a message has enabled security on the U3 which is demanding a "password" of which I have no recollection of even creating upon first usage. I have used up two probable choices with no success and am down to just 3 before "permanent freeze" of internal data. Is there a "generic" password I may be unaware of. Why is the security still enabled when the onboard McAffee trial subscription has expired? I have within stored crucial anti-spyware/malware programs and a beautiful gallery of NASA/JPL/Hubble JPEG's I collected for a college project due soon!!! Mayday! Mayday! Any heroes still out there to help????? Please aidez-moi!!!!
SOURCE: PC Locks Up
Try booting with the device already in the USB port. If that doesn't work, try doing the same accept into safe mode. Once you can recognize the drive, reformate the drive. This might resolve your issue.
SOURCE: SanDisk 2 GB Cruzer
hai,
it seems ur flash drive is infected with some virus
scan the drive with an updated virus scaner.
if this does not succeded, copy ur data to the HDD and go for a full format.
good luck
Please don't forget to rate or accept the solution
SOURCE: lost data
if it show u currepted the use hp usb disk formet tool
the use easyrecover tools for recover data
and if it
wil not showing data but space is used then just go to show hidden file and su ur data
SOURCE: i have lost data from my sandisk 2gb cruzer micro
Presuming that you would like to recover your data, I suggest you use a Free Recovery Tool called "PC Inspector". It has relieved a few headaches for me and is easy to install and use.
Download from here:
http://download.cnet.com/PC-Inspector-File-Recovery/3000-2248_4-10118663.html
As always, please check the file for unwanted nasties before installing/downloading
SOURCE: I accidentally remove my "LaunchU3"
Are you sure you can't access it anymore?
LaunchU3 is only a quick launch program that comes with Cruzer flash drives. Even if the program is deleted, you should still be able to access your other files. Just go to Start -> Computer and your flash drive should be listed next to your hard drive.
If that doesn't work, then perhaps you deleted other files along with LaunchU3. In that case, you will have to use data recovery software to un-delete the files.
Try this:
http://download.cnet.com/VirtualLab-Data-Recovery/3000-2248_4-10610841.html
