While it is in my pocket as locked, frequently voice command has been activated without any operation. Or sometimes it was connected to the internet. I guess it is too sensitive or something is wrong. How can I fix it.
Hi. To turn Voice
Guidance off, press the Option button. To find the settings, press up or
down slowly until you hear a beep. Press OK to enter the voice guidance
menu. From that his menu: Voice Guidance On/Off: Use arrow keys on
remote to toggle on and off.
NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
Page 19 of your manual: Activating Voice Command Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command". 1. From main menu, touch Tools > Voice Command > Customize Phrase. 2. Enter a new wakeup phrase. 3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Voice command is activated by the side button that is alone (right side if your facing the phone's screen) when the phone is closed. I don't know how to prevent the phone from doing that, but I do know how to make sure the phone does not say "Please say a command."
Menu Settings and Tools (Far right icon) Tools (#2 on the list) Voice Commands (#1 on the list) Hit settings, which is going to be the right bumper button (above the CLR key) Go to prompts (#5 on the list) Mode (#1 on the list) It will be currently set on prompts, which is why it says "Please say a command." You can either set it to readout or tones only. Tones produces a short beep. Readouts only displays text (no noises). Being that you have your phone on silent, I assume you want readouts.
That will at least prevent stop the phone from making random statements in your pocket. Hope this helps.
I have a 2006 A8 and if you need help with the command say "help mmi" or when you are in one of the following modes: radio, CD, or Navigation. you can say "help ." This should provide you with all the commands the voice command can understand.
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
To activate voice commands: 1. In your menu, go to MY STUFF MENU 2. select TOOLS 3. select Voice Command 4. Enable the on/off option
How to use it:
Call <Name or Number>: This function is activated only when if user says command “Call” and name stored in address book or specified phone number. Handset, voice engine inside recognize users utterance handset, displays name lists from your phone’s address book or phone number, however noise might caused to display candidates. Additionally user can superimpose number type at the end optionally, such as “mobile”, “home” or “office”.
its a common problem with voice commanders...as one cannot expect a low end processing device to process your voice with 100% accuracy...even the best of best voice processors that run on high end computers are about 80-90% accurate...I suggest you reinstall the voice commander and re-create the voice tags...
