SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
