TP-LINK TD-W8901G Router Logo
prem Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My router always loss internet conection while i start downloading
Anonymous
Level 3:
  • TP-LINK Master 32,281 Answers
  • Posted on May 30, 2012
Anonymous
TP-LINK Master
Level 3:
Answers
32281
Questions
Helped
7905750
Points
102259
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
2answers
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
2answers
Loss of speed with wireless
Wireless conection will only run as fast as your slowest device. i.e.
802.11 only supported a maximum network bandwidth of 2 Mbps.
802.11b supports bandwidth up to 11 Mbps.
802.11g supports bandwidth up to 54 Mbps.
802.11n connections should support data rates of over 100 Mbps.
So if you are running a mixed network with lets say a 802.11b wifi card on a laptop and a new laptop with 802.11n, your speed will only be that of the 802.11b card.
I hope that helps.
1helpful
2answers
My D-Link DSL-G604T router keeps losing conection to the internet
I know only one working solution for this problem. Download and install Router Commander that was developed for fixing this kind of problems.
We have a PC conected to the enternet with a modem. We have recently bought an iMac computer and a wireless-G broadband router so we could conect the iMac to the internet too. We have the router conected...
For connecting your mac computer you may need to configure router . What you can do you call call linksys Free Technical support - Direct number is 1800-326-7114
Loss of internet connection to desktop with WRT 160 N
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
I can not connect wirelessly to my internet. I have a linksys cable modem and a linksys wirelesss router WRT545S. I also am using vista. Today I switched my internet provider from ATT to Comcast. I am...
just get in contact with your new ISP as they will provide you info regarding setting up the router
u can try opening the router page
click on start
in the start search type in run and press enter
you will get a box
just type in cmd
and then press ok or enter
on this black window type in
ipconfig
and press enter
look for a default gateway
it may start with 192.168.x.x
put this number in internet explorer and press enter
check if you are able to open the router page.
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
