SOURCE: new troy bilt mower (pony) when you put it in
It is a safety feature. You can disconnect it if you want. Where ever you place the tractor in reverse there will be a switch . Try disconnecting the switch an use a piece of wire to act as a jumper. You will put the piece of wire with insulation on it so it doesn't short out into the ends of the wire harness that is comming to the switch. Once the jumper is installed try starting the tractor and engage the blades and put in reverse. If it does not shut off and runs alright then you can cut the end off of the wire and using a wire connector join the two wires and wrap with electrical tape. YOU HAVE TO BE VERY CAREFUL AFTER YOU DO THIS BECAUSE THE BLADES WON'T SHUT OFF WHEN IN REVERSE!!!
Let me know if this helps.
roundo4
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
SOURCE: I threw the drive belt
I had found a site where you can download the schematic diagram of your device so that you can install the belt. Just click_here so that you will re-directed to the exact site.By the way, you have lots of options to that site, just select the best for your concern.
Thanks.
