Need to download a service manual for a Dell laser printer 1320c
Apparently others have tried to obtain a service manual for that model, and one was not available. Frustration was expressed, but it did not result in obtaining a service manual for that model.
https://www.dell.com/community/Printers/1320c-Service-manual/td-p/5112626
Other sites might have some solutions for problems with that model, even though not a service manual.
Example:
https://www.dell.com/support/article/us/en/04/sln153516/replacing-the-phd-unit-on-1320c-2130cn-2135cn-2150cn-2150cdn-2155cn-2155cdn-dell-laser-printers?lang=en
Here is another approach to try for repairing it. Perhaps a service manual for a similar model, since your is from 2013, would be helpful. Since the link above from Dell shows other model numbers using a similar part replacement so maybe service manual for one of them could be located: 2130cn 2135cn 2150cn 2150cdn 2155cn 2155cdn
2130cn service manual from 2010:
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%202130cn%20Full%20Manual.pdf
2135cn service manual from 2008:
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%202135cn%20Full%20Manual.pdf
2150cn service manual (registration required to download)
https://www.scribd.com/doc/202253581/Dell-2150cn-Service-Manual
Miscellaneous service manuals:
https://www.mpsprinters.com/categories/dell-service-manuals.html?sort=pricedesc&page=2
Sorry to put so many links, but perhaps one of these will help solve problems with that printer.
SOURCE: My dell laser printer 1320c has printer error code
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Testimonial: "Thanks very much for your help I will now order a new drum cartridge."
SOURCE: Lost CD for Dell Laser Printer 1320c installation setup
Check this link and click on the "Download Now" button. The driver is 8MB.
http://www.soft-go.com/download_driver/Dell-Color-Laser-1320C_137.html
Have a great day!
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
SOURCE: my dell 1320c laser printer is starting to sound
Mine is doing the same thing and no luck on anyone advising where to lubricate the inside the unit. I'm sure it's a simple fix...mine honestly just sounds like it needs "oiled"... but where to "oil" it is the big question. It still prints beautifully. Can anyone out there help?
SOURCE: Dell Color Laser 1320c printer. The left side of
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
