Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Treadmill speed problems
I have a trimline 3600.1 treadmill and the peed will not adjust. It goes from stop to fast with no slow spped available. I checked the speed sensor and it is 1/4 inch from magnet. I tried to calibrtae the spped but it won't aloow me to adjust to .5. can you help?
  • 4 Answers
Http://webpages.charter.net/chestnuts/Trimline%20Owner%27s%20Manual-1600-2600-3600-4600.pdf
Posted on Jan 13, 2009
6ya staff
SOURCE:
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Trimline treadmill repair e1
please LUBE the deck belt with silicone inmediately.
God bless you
Jun 04, 2013 | Exercise & Fitness
Treadmill giving me error P1U
Got it. See last page of manual found here: http://webpages.charter.net/chestnuts/Trimline%20Owner%27s%20Manual-1600-2600-3600-4600.pdf
i.e. stuck in calibration mode.
1. Press & Hold PROGRAM INTERVAL, SPEED DOWN and POWER
2. Release SPEED DOWN only (must hear a beep or repeat 1 &2)
3. Release the other two
4. Press PROGRAM INTERVAL (treadmill will move up or down)
5. Press PROGRAM INTERVAL (treadmill will move up or down)
Calibration is complete. Enjoy your exercise!
Eric
Ottawa, ON
Aug 29, 2011 | Sport & Outdoor - Others
Our Weslo Cadence Dx12 treadmill will only operate at the highest speed and will not turn off without the safety key. The speed cannot be adjusted to slower speeds.
Go to Radio Shack and buy some contact cleaner. Clean the peed control on the console. If that doesn't solve the problem, you will need to replace the motor controller PCB..
Dec 11, 2010 | Treadmill Doctor Weslo Cadence Dx12...
Walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Feb 27, 2010 | Cadence Weslo 4200 Treadmill Walking Belt
How do you adjust the speed for viewing pictures on the dvd player
There should be a setting that lets you adjust it in the setup menu. Although it may only offer fast or slow as a spped options. Good Luck.
Aug 27, 2009 | Oritron DVD4119
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
561 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
