SOURCE: Expected life time of Sta-Rite heater?
Thank you for posting your question here on Fixya.com.
Overall heater life is often dictated more by the pool maintenance history and chemical usage than location. Generally speaking up here in the Midwest you can expect 12 - 15 years of service life from a heater. More if it gets pampered with such treatment as proper winter covering and regular cleaning and maintenance. Far less if chemical issues arise in a pool and are not dealt with properly. A heater can fail in a matter of weeks if water conditions are that poor.
So, to answer your question; with proper installation, maintenance and water treatment I’d put it at 15 – 18 years before the heater will have spent itself from wear.
If this answer does not fix your problem or you are not sure about part or all of this post, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: STA RITE HEATER SR333NA WONT HEAT. THE BLOWER
is the light is flashing 3 times if not it's more of a
open
switch is the problem. otherwise only other solution that is offered by
manufacture is to replace the control panel module
I also found the part at pool plaza on the internet for $195
Good
luck with your repairs and I hope this helps you solve the problem.
