It was three clicks then on now it's up to ten or more clicks before it's stops clicking.
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
SOURCE: PDS22SBSALSS Clicking Noise/ Temperature Control Panel
It is possible to change out that relay...if your unit has one. This is usually a small plastic box on top of the compressor...but not a round tubular thing...which is the start capacitor. Just make sure you are careful...take out the plug. If you're messing with the capacitor...it has terminals which do contain hazardous voltage. Discharge with a screwdriver across the terminals. Generally, the relay is the thing which gives the symptoms you're facing. Change both and you've probably got it...they're cheap. Not all models have both.
SOURCE: Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
SOURCE: I have a GE side by side fridge. First the water
You have a main control board that is going out . Part number WR55X10942 . The clicking noise , sounds like one of the modules , is shorting occasionally . The control board , is located behind the refrig , behind an 8 " X 10 " panel . This board , is easily replaceable .
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
