SOURCE: ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
SOURCE: Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
SOURCE: have a pioneer avh-p3100dvd, how can i make the
YOU NEED TO BUY A SWITCH FROM WALMART($3), 2 OR 3 PRONG, CONNECT THE GREEN(PARKING BRAKE WIRE) TO THE POWER PRONG ON THE SWITCH AND CONNECT A GROUND WIRE FROM THE GROUND PRONG ON THE SWITCH TO ANY PEICE OF METAL ON YOUR DASH...FLICK THE SWITCH TWO OR THREE TIMES AND NOW YOU CAN WATCH VIDEOS WHILE IN MOTION.
