Walgreens By HoMedics Automatic Wrist Blood Pressure Monitor 1ea Logo
Posted on May 28, 2012
What does a P in a circle in the left hand corner mean
This is sn 08041110 I took b/p and pulse and a capital P with circle around it appearws in the left hand corner what does this mean
Britta Brmick
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2018
Britta Brmick
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4260
Points
P means pre hypertension
1 stage 1 hypertension
2 stage 2 hypertension
We have a Sentry 1330 safe that belonged to my grandfather. He passed last year and we cant find the combination or the SN anywhere? Is there a way to crack this safe?
you can get a rare earth magnet and place it in a sock so you will be able to remove it from safe .. place magnet on upper left hand corner of door and move around until you turn handle
A number greater than -5 but less than or equal to 5
Greater than -5, means infinitely close to -5, but greater than it, so it is on the right hand side of it. On a number line, we indicate this with an open circle at -5.
Less than or equal to 5 means 5 and everything less than 5. On a number line, we indicate this by drawing a circle at 5 and filling it in.
O------------------------------------•
Sorry, I couldn't find a filled in circle to be the same size as the capital o;)
Good luck,
Paul
A warning light on my mini one diesel 2011. a yellow circle with capital (A) in centre
I think you mean the yellow circle with the triangle and the exclaimstion point? ... That would be a service light. If it says ABS in the center (orange warning light ln the right, not left) then your brake system needs inspected or serviced.
I want to send message in capital letters i.e. in upper case. How I can do this
Hi!
On your keyboard, on the Left hand corner there is a Caps Lock key/button. Press that and try checking when you type if its all in Capital letters.
Hope this helps.
3answers
Where is the start button?
If you have a windows based system it is by default in the bottom left of the screen with a windows logo on it.
7helpful
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
1helpful
1) is an exclamation point in a circle with rigid edges left hand corner 2) exclamation point within parenthesis on the right hand corner
Need to know the year and model of your Ford and I can look up. Reply to this and I'll get an email letting me know. Little confused at how you are wording it but will do my best to figure out. Is one of them like the picture I have posted below. If it is let me know in the reply and will let you know what it means if it is one of the icons you are seeing.
What does a symbol that has mph with a circle around it and a 1 in the top left corner mean?
It's a programmable speed warning. Your owner's manual will describe how to cancel, adjust, or reset it.
Psp analog joystick
thats what happens when you lose the silicone pad with copper connections inside.
another posibility is that you didnt tie the screws hard enough. thatr worked for me.
if you dont tie the hard enough the analog goes to the upper left hand corner. and in the game, the player might walk around in circles, lol
Top Walgreens Health & Beauty Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
