Samsung YP-S2 MP3 Player Logo
Posted on May 28, 2012
How do you turn it on - Samsung YP-S2 MP3 Player
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1006
Points
Press and hold button in middle
Why my blinkers dnt work but hazards do in 00 Pontiac Bonneville
You have no clue, guessing won't fix it , having wiring diagrams an using a DVOM - digital volt ohmmeter will. Testing an reading how they are suppose to work will. factory service info.
Turn Lamps
Battery positive voltage (B+) is supplied at all times to the turn signal/hazard flasher module in the hazard switch assembly from the rear fuse block T/SIG HAZ Fuse. The turn signal/hazard flasher module is permanently grounded. Battery positive voltage (B+) is supplied with the ignition switch in the ON or START position to the turn signal switch in the instrument panel from the rear fuse block IGN 1 Fuse.
When the turn signal switch is placed in the position to indicate a LH turn battery positive voltage (B+) is input to the turn signal/hazard flasher module Left Turn Input. In response to this input the turn signal/hazard flasher module supplies battery positive voltage (B+) in an on and off flashing pattern to the LH turn lamps and the instrument panel cluster (IPC) LH Turn Input. The LH turn lamps are permanently grounded so the LH turn lamps light when they have power, ground and turn off while power is removed. The IPC will also light the LH turn indicator.
When the turn signal switch is placed in the position to indicate a RH turn battery positive voltage (B+) is input to the turn signal/hazard flasher module Right Turn Input. In response to this input the turn signal/hazard flasher module supplies battery positive voltage (B+) in an on and off flashing pattern to the RH turn lamps and the IPC RH Turn Input. The RH turn lamps are permanently grounded so the RH turn lamps light when they have power and ground and turn off while power is removed. The IPC will also light the RH turn indicator.
Did the turn lamps operate properly?
Go to Step 3
Go to Turn Signal Lamps and Indicators Inoperative - One Side
Disconnect the instrument panel cluster (IPC) connector.
Connect a test lamp between the inoperative turn signal input circuit at the IPC connector and a good ground.
Turn ON the ignition, with the engine OFF.
Move the turn signal switch to the inoperative turn position.
Does the test lamp turn ON and OFF with the turn signal lamps?
You people need to quit trying to play auto mechanic , you have no clue about automotive electrical circuits .
1helpful
Pontiac Grand Prix 2005 - my left turn signal on the dash board blinks faster than usual but the left signal lamp in the front of the car does not flash! It remains steady. What's wrong ? Also how could I...
Turn Signal Lamps
The STOP/TURN/HAZARD fuse in the instrument panel (I/P) fuse block supplies battery positive voltage to the body control module (BCM) for the turn signal lamps. When the turn switch is placed in the LEFT TURN or RIGHT TURN position, ground is applied from G202 through the turn switch, to the turn signal switch signal circuit and to the BCM. The BCM then applies battery positive voltage to front and rear turn signal lamps supply voltage circuits. The left front turn signal lamp is grounded at G100, right front at G101, left rear at G301 and the right rear is at G302.
Turn Signal Reminder
The driver information center (DIC) activates the turn signal warning as requested by either turn signal switch. The turn signal warning sounds when the following occurs:
• The ignition is in RUN.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to battery positive voltage transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (0.75 mi) by counting pulses in the rolling odometer class 2 message.
The DIC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing within 1 second, no transitions from open to battery positive voltage in either of the turn signal control circuits, left turn or right turn.
My first step would be to hook up a factory scan tool an check for DTC'S - diagnostic trouble codes
DTC B3948 Left Front Turn Signal Circuit
Circuit Description
Ground is applied to the turn signal switch. When the turn signal switch is placed in the turn left position, ground is applied to the body control module (BCM) through the left turn signal switch circuit. The BCM then applies a pulsating voltage to the LF and LR turn signal lamps through the LF and LR turn signal voltage supply circuits.
What's the left rear lamp doing ? Flashing fast ?
DTC B3950 Left Rear Turn Signal Circuit
2answers
2004 Chevy Silverado dash lights and turn signal stopped working. Do you have a wiring diagram?
You probably need a turn signal / hazard flasher module located in the under hood fuse box. These go out all the time .
Turn Signal/Hazard Lamps
The IGN E 10-amp fuse in the underhood fuse block supplies battery positive voltage to the turn signal/hazard switch assembly. The FLASH 25-amp fuse in the instrument panel (I/P) fuse block supplies battery positive voltage to the turn signal/flasher module and ground is supplied at G200. When the turn signal switch is placed in either the LEFT or RIGHT position, a voltage signal is completed from the turn signal switch to the turn sign/flasher module. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the turn sign/flasher module. The turn sign/flasher module then sends an on-off voltage signal through the LT TRLR, RT TRLR, LT TURN or RT TURN 10-amp fuses in the I/P fuse block to the appropriate turn signal or to all 4 fuses for hazard operation. The instrument panel cluster (IPC) indicators receive voltage from the LT TURN and RT TURN fuses as well as the driver door module (DDM)/passenger door module (PDM) for the mirror turn signals. The DDM/PDM has no function or control of the mirror turn signals other that a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators. The front turn signals are grounded at G100. The rear turn signals are grounded at G401. The Mirror turn signals are grounded by the DDM/PDM.
2answers
Had replaced turn singals bubls on my 2004 chevy venture van still wont. Work whats the problem PLEASE Thank YOU so much
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
• The Rear Turn Lamp
• The Turn Signal Indicator
• The Sidemarker Lamp
• The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Drive belt john deer scott mower detail
Computer ?? Turn Off ??? ???? ???? - Shut Down Computer.
????? ?????January 3, 2018 TP Staff??????
Computer ?? ??? (Shut Down) ???? ?????
?? Computer ?? ???? ????? ?? ???? ?? ?? ?? ??? ??? ?? ??? Computer ?? ???? ???? ????? ??, ?? ??? ?? ???? ??? ?? ?? Computer ?? Turn Off ???? ????? ??. ???? Computer ?? ???-??? ?? ???? ???? ?? ?????. Computer ?? Shut Down ???? ?? ????? Computer ???????? ???? ??. Computer ?? ????? data ?????? (Save) ???? ?? ?? Computer ?? Turn Off ???? ?? ????? ?? ?? ??? ???? ??. ???? ??? ???? Computer ?? Turn Off ???? ???? ??. ?? ???? ?? ?? ???? Computer ?? Turn Off ???? ??.
???:Computer ?? Turn Off ???? ?? ???? ?? ????? ?? ????? ???? ?????.
1. Computer ?? Turn Off ???? ?? ???? ?? ????????? ?? ?? ?? ???? ????? ???? ??? ??? ?? save ?? ??? ??. ???, ??? ??? ???? ?? ?? ??? ?? ???? ??.
2. ?? ??? program ?? ????? ?? ??? ?? ?????? ?? Computer ?? Turn Off ???? ?? ???? ??? ?? ???? ?????.
3. ???, ???? ??? disk ???? ??? ?? ?? ??? ?? Computer ?? Turn Off ???? ?? ????? ????? ?? ???????? ??? ?? ?? ???.
?? ?? Computer ?? Turn Off ???? ?? ??? ??????? ????? ??. ?? ??? ??? Computer ?? Turn Off, ??? Shut Down ???? ?? ???? ??, ?? ????? ?? ???? ???????. ?? ???? Computer ?? Turn Off ???? ??.
??? ?? ????: Computer ?? ???? (Start) ???? ???? ???
Computer ?? ??? ???? ?? ???????
???? 1.
1. "Windows Start Button" ?? ????? ????. ?? ??? ??-????? ?? "Windows logo key" ????.
2. Start Button ?? ?? ????? ???? ?? Start Menu ??? ???? ??.
3. ??? Start Menu ?? "Shut Down Button" ?? ????. ?? ???? Start Menu ??? ????? ?? ???? ??????.
4. Shut Down Button ??? ?? ??? ???? ??, ???? Shut Down ?? ????? Arrow. ?? ?? ???? ???? ??? ?? ????? ???? ?? ?? ????? Computer Shut Down ?? ?????.
5. ???, ?? Arrow ?? ????? ??????? ?? ???? ????? Shut Down Button ?? ????? ??? ?????. ????? Computer ?? Turn Off ???? ?? ??????? ??? ?? ??? ???? ??.
???? 2.
?? ?? Keyboard ?? ?????? ?? Computer ?? Turn Off ???????. ?? ??? ??? ????? ?? ??? ??. ?????, ???? Computer ?? Turn Off ???? ??? ??? ?? ??? ???? ??. ?? ????? ??? ?????? ??? ?? ???? Computer ?? Turn Off ?? ???? ??. ?? ??? ?? ????? ?? Computer ?? Shut Down ???? ??.
1. ???? ???? ??-????? ??Alt + F4?? ??? ?????.
2. ?? ??????? ?? ????? ?? ????? ?????? Shut Down Window ????? ????? ??? ??.
3. ?? ???? Shut Down Window ?? Drop Down List ?? ????? ??. ???? ??? ?? Arrow ?? ????? ????.
4. ?? ???? Drop Down List ?? Shut Down ?????? ?? ????? ???? ?? ???? ?? select ?? ???.
5. ???? ??? ??-????? ??Enter????? ?? ???? Computer Shut Down ?? ?????.
???? 3.
?? ????? ???? ???? ?? ??????? ??? ??. ?????, ?? ????? ?? Computer ?? ??? ?? Turn Off ??? ???? ?????. ????, ????? ???????? ????? ??. ????? ?? ????? ?? ???? ????? ?? ??? ??.
1.???? CPU, ???? Case ?? ???? ???, ?? Power Button ?? ????? ?? ???? Computer Shut Down ?? ?????
??, ?? Computer ?? Turn Off ???? ?? ???? ??? ????? ?? ?????? ?? ???? ??. ???? ???? ?? ???? ?? Computer ?? ??? ?????? Turn Off ???? ?????. ?? Computer ?? Turn Off ???? ?? ???? ??? ????? ?? ????? ??? ???? ?????. ????, ?????? ?? ?? ?? ??? ???? ??? ?????? ??? ??.
May 04, 2018 • Garden
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Passenger side turn signal flashes faster but dont work even at day runing light, comes on when head lights are on, replace bulb and socket because was melted but stilldoes the same
Turn Signal Lamps
The Rear Turn Lamp
The Sidemarker Lamp
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
2answers
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
How to end turn
To end your turn there is an end turn in the bottom right of the screen, the turn ends when a turn timer (if enabled counts down to zero) or when all human players have pressed end turn.Turns happen one at a time except during wars (on the default settings) and the AI's turns happen simultaneously. For more info on turns look at the ingame turn settings, which explain it a bit.
Turn signals wont turn off
my turn signals turn on ok but won't turn off after the turn is made, I have to manually turn them off. is this a fuse problem or could it be something else
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
